windows not displaying on Floor plan
bhetsua.tinoco
bhetsua.tinoco
I modified the dimensions of my windows to 24"x24" and then I attached them to my walls and I was able to see them on Floor plan, however, when I switched to Elevation view and moved the walls a couple more feet from the ground my windows are no longer visible on Floor plan. If I move my cursor where the  windows were attached I can see that they are still there because they get highlighted in blue. in my picture you can see that one of my windows is highlighted in blue when i move my cursor however I also have another window right next to it that is not shown unless I move my cursos. Can someone please help me?
Jerry.jc.Wu
You might want to check your View Range, Your cut plane seems like too low for the window when you move up in elevation. You can try to use a plan region to show that window if you want to keep the overall view range.
bhetsua.tinoco
@Jerry.jc.Wu , my problem is not on the elevation view because I'm actually able to see the windows on 3D and south elevation, my problem is that they are not showing on my Floor plan. I've attached a second picture where my windows are still attached but you cannot see them floor plan only visible on 3d and south elevation.
Jerry.jc.Wu
Yes, see your window in 3D is way higher than the other windows, there's a big chance that your view range for the floor plan is lower than your window, so the window won't show up because the view is not cutting through it.
bhetsua.tinoco
@Jerry.jc.Wu , Thank you so much. I did what you showed on the picture, i changed my cut plane to the height of my first floor and now I'm able to see the windows.
jerry0625
Glad I helped, sorry I used the wrong account to answer the question, and like I mentioned, you can use a plan region to just adjust the view range of the window area.
Jerry
