Windows 11 compatible
brianwclayton1969
brianwclayton1969
Good afternoon, I have seen that Windows 11 is out, this is a general question about Autodesk products. I was wondering are AutoCAD and Revit versions compatible with Windows 11 now or do users need to wait couple of months before updating to Win11.
Thanks Brian
mariano_biagioli
Hi, I haven’t found any problems installing Autodesk products in windows 11. Also, updating windows with my adsk programs already installed neither.
If I helped you, please mark as a solution. Thanks.
mariano_biagioli
Hi, I haven’t found any problems installing Autodesk products in windows 11. Also, updating Windows with my Autodesk programs already installed neither.
If I helped you, please don't forget to mark it as a solution. Thanks.
edwin.prakoso
If you check AutoCAD and Revit system requirements, Windows 11 is not listed as a supported OS yet.
I would wait until it is officially supported, especially for the production environment.
Cheers,
Edwin Prakoso
brianwclayton1969
Thanks for your assistance.
Brian
nathan.terranova
This post indicates AutoCAD 2021 and 2022 fully support Windows 11 even though it is not listed on the system requirements page for AutoCAD
RDAOU
@brianwclayton1969
It is compatible and Autodesk did extend support to cover windows 11
https://blogs.autodesk.com/revit/2021/12/01/autodesk-revit-now-supports-microsoft-windows-11/?_ga=2....
