- Mute
- Permalink
- Report
I have three family objects attached. All work find in the family editor but don't work in a project.
MP-Window_Sgl_Plain works OK if there is only a single instance of it cutting into a wall, but the moment I try and insert a second into a wall it throws up an error "Can't cut instance of Fixed Pane Window out of Wall."
With this one I have 3 voids cutting, one for the inside reveal, another for the window frame, a final one for the external reveal. These were created by extruding in elevation.
Mp-Window_Sgl_Plain-Void test.rfs I changed things so I had only 2 extrusions, done in plan. I cannot insert this into my project at all.
Mp-Window_Sgl_Plain-Void test2.rfa I changed it again so there was only 1 extrusion, again in plan. Again I cannot insert this into my project.
I can get a void to cut a wall if it is just on the one side, but running all the way through fails, even a single cubic void object doesn't work.
Any suggestions?
I should add that my windows (at least the last 2) work as objects right up to turning the extrusion I've created into a void, it seems it fails only once the void is set to cut the generic wall, it is only then it won't load into a project.
