Window Tags and Schedule
PhilvK
Advisor Advisor
Message 1 of 10
PhilvK
I’ve created a sample project and inserted 5 windows into the walls. The 5 windows are comprised of only 2 types. When I create a schedule however, each window has its own “mark” numbered consecutively. How to you get the tags on the plan to match the schedule? I apologize if this is incredibly simple, I just can’t find it.
Replies (9)
Message 2 of 10
BIMologist_
The Window TAG is using the TYPE MARK and the schedule is using Mark (Instance)
Open the Window Tag Family. / Edit Family
then follow the graphics
Load it back in the project.
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
Message 3 of 10
PhilvK
Got it! Thanks.
Message 4 of 10
PhilvK
Is it possible to have both the Tag Mark (number) and the Type Mark? For instance, if I have 30 windows, and only 3 types, I get a schedule with 30 entries, and each entry Type is either "A", "B", or "C".
Message 5 of 10
David_W_Koch
You should be able to create a custom tag that has both the Type Mark and the Mark parameters (in separate labels or in the same label, depending upon how you want them displayed).  Keep in mind that Revit will want all of the Mark parameters to be unique, and will give you a warning if they are not.  So if your Type Marks are letters and your Marks are numerals, you could have A1, A5, A7, B3, B4, B8, C2, C6, C9.  If you want A1, A2, A3, B1, B2, B3, C1, C2, C3, you will get warnings about the identical Mark values.
From your description, it sounds like you are showing the Type Mark in your schedule.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 6 of 10
Clear, correct and concise. Txs!!
Message 7 of 10
exactly what I have been looking for. many thanks! cheers!
Message 8 of 10
L.S.
I'm having the same issue with window tags (wanting to have unique tags for each window regardless of type), so I followed your steps to fix the issue, but I must be doing something wrong because it's not working. Any idea what's going on?
Message 9 of 10
yes_and_no
Create separate labels, Mark and Type Mark, align them next to each other in yr tag family, reload.
Message 10 of 10
luisPDAN6
We usually have a tag that has Mark and Type mark in separate lines of the same label. The mark gives the unique number, usually related to the room for geographical location, and the Type Mark gives the ID of that type for specification and fabrication.
