Window tag / mark visibility
Ephippus
Ephippus
Hi, I have a model with an existing phase (Main Model) and an extension phase in different design options.
I don't want to see window tags in the existing phase.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/C...
suggests I could make a new parameter but I can't do line 5 as there is no drop-down list that I can see.
This must be a common intention, how is it done?
Jon
chrisplyler
Window tags, along with other tags, are Annotations. Annotations are view specific, meaning they do not exist in the model as a whole, but instead exist only in the view in which they were placed.
So if you have a view in which you do not want to see some tags, select them and delete them, or at least hide them.
Sahay_R
You can hide the tags by view, or create a view template, with VG>>Annotation Categories and uncheck Window Tags
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
