WINDOW SWING
WINDOW SWING
ethannavah
Message 1 of 19
WINDOW SWING
ethannavah
Right Left casement window swing does not match the elevation. ANY SOLUTION?
Replies (18)
Message 2 of 19
Lachlan-JWP
This is far too vague to offer a helpful solution. Can you post the family or some screenshots showing the issue?
Message 3 of 19
ethannavah
Message 4 of 19
ethannavah
YOU CAN SEE ON THE FLOOR PLAN IT SWINGS THE OTHER DIRECTION FROM THE ELEVATION VIEW
Message 5 of 19
Lachlan-JWP
That's the way they are supposed to look. Both elevation and plan are showing the windows hinged on the right.
Message 6 of 19
ethannavah
SORRY BUT THE HINGE IS WHERE THE 2 SWING LINE CONNECT
LOOK AT A REGULAR DOUBLE CASEMENT WINDOW
Message 7 of 19
Mirror the elevation swing lines in the family.
Message 8 of 19
ethannavah
I THOUGHT ABOUT THAT BUT... THE SWING DOES'NT SHOW UP IN THE FAMILY EDITOR
Message 9 of 19
Did you open the elevation view in the family?
Message 10 of 19
ethannavah
YES
Message 11 of 19
Yeah; change the orientation to how you want it.
Too easy? If so, you could probably write a Dynamo Routine to do it for you.
Message 12 of 19
ethannavah
HEY BRO! YOU PROBABLY DID'NT FOLLOW THE WHOLE TREAD...
MY ISSUE IS THAT IT DOES'NT MATCH THE SWING IN THE FLOOR PLAN VIEW AND THE ELEVATION VIEW
Message 13 of 19
Yeah, I saw that.  Looks like a 10 second fix to me.  If it ain't, then post the family here and let's see what's going on.
Message 14 of 19
ethannavah
IS THIS WHAT YOU WANNA SEE?
Message 15 of 19
Do you really think that's what I want to see?
Never mind. I'm outta here.
Good luck.
Message 16 of 19
Lachlan-JWP
If you can't find the swing lines in the family editor you're going to have to post the family so we can have a look.
Message 17 of 19
No. that is a 3D view.  Open an Elevation view.
Message 18 of 19
mhiserZFHXS
@ethannavah wrote:
HEY BRO!
Message 19 of 19
mirandamoenarch
Community Visitor
Community Visitor
The issue is that the family parameter names are backwards. You have to go into the Casement Swing family then modify the parameter values by editing the names. Switch RH to LH and vice versa. Then the swings will operate correctly. Make sure you save it to the casement window type and then load and save into your file. Should fix it.
