Window sweep; family editing
AzWoodWarrior
AzWoodWarrior
I have been trying to figure out a way to have 2 different sweep profiles for the same window family. As you can see in the picture one sweep will end at the top of the stone stacked wall the others have to be elevated to go over the countertops. How do you go about having 2 types of sweeps? I'm almost bald from pulling my hair out...
Got a picture?
...maybe 2 sweeps controlled by one visibility parameter?
Just throwing something against the wall to see if it sticks while waiting on that picture.
AzWoodWarrior
That's weird, I attached a jpeg, let's see if it works this time. I think your solution may just work though
Can't tell much from this picture, but if you want two different trim options is the same family, create a Yes/No Parameter and use it to toggle the Visibility of the two trims.  When one's visible, the other is not visible.  A simple Parameter formula accomplishes this:
Trim 1 Visibility = not(name of Yes/No Parameter)
Trim 2 Visibility = name of Yes/No Parameter
