Window parameters- Instance to type
samanthaL98BX
samanthaL98BX
I have downloaded a revit window family from my window manufacturer.
The width of the window is set as an 'instance' parameter so when I have gone to do my window legend, I can't get it to show each window width, it just reverts back to the default width.
I've tried to change the parameter so that I can just create a new window component for each style, however when I edit the window family to try change the 'width' parameter from 'instance' to 'type' it is greyed out. Does anyone know why this might be and how I can change it?
Or know of a way that I can get my window legend to display different 'instance' parameter widths?
Open a plan or elevation view of the window family where the Width dimension parameter is placed, select ot and change from Instance to Type from the ribbon.
samanthaL98BX
That worked! Thank you for the quick response.
Such an easy fix!
