- Mute
- Permalink
- Report
Hi all,
I have prepared a window family family as per our project requirements with nested components. The window has two separate components placed on top of each other. When I place this in project, I am only able to see the cut of upper panel and not the bottom panel. I have tried changing the view range of both project and family(each component) and adjust to see if it comes at any of the preferred ranged but it fails to do so. Kindly help me on this. I am attaching the file. Thanks a ton in advance.
I am using view range as 1600(cut plane) which helps me view all the important parts of my plan. The size of window I will be using is 1200x1350mm. Also attached the images for reference.
