Window Family lIne thickness issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a long standing problem that I would love to surmount. I do a lot of designs with nailfin windows. The rough openings are a little bit bigger than the window frame. This rough opening line is represented by a thin line just outboard of the window/wall cut line which is more strongly associated with the sash and the window frame. I've figured out how to pull dimensions from this rough opening line in the family usingstrong reference lines and a void form instead of a cut line but I haven't figured out a way to supress the wall cut line so the point at which the dimension is pulled is more strongly and precisely represented by a thinner line than the usual wall profile line. I've attached an image below that first shows (with detail lines) what I would like to achieve. Below it is a representation of my window family in an actual Revit wall family. How do I get rid of this mudiness?! I would really like to figure this out. Should I put a white symbolic line on top of the wall cut line? This feels like a sloppy practice but I'm open to anything. Any help is greatly appreciated.
Mike
