Window/ door schedules, sheet path
info
info
Is it possible to show in schedule list which sheet is hosting the window/door.
For example, I have a list of windows with measurements and material info. I would also want to list to show in which sheet is the picture and more details of this window. I would also like it to update if I change the name for this sheet or if I create new window and place it on new sheet.
I would also like to use this same method for multiple object types
Thanks!
Alfredo_Medina
The question is not very clear, but let me try...
There is usually one sheet that contains all the information about the windows of the project. This sheet contains the schedule of windows, the elevation types, and the details for sill, jamb, and head. In a large project, this might take more than one sheet, of course. All these sheets will be listed in the index of sheets.
@info
You cannot do that unless manually enter the sheet information in a parameter of the windows category. Or develop a dynamo script to do it for you.
With that said, this is a CAD mentality that is not suitable when you work with BIM.
