cant use vray trial for revit 2018
im trying to render using vray but these error message is coming don know why .....  pls guide me
-FDC-
Seems like this error has nothing to do with Vray.
You installed modelo exporter!
I don't know this software but it is something for VR.
https://apps.autodesk.com/RVT/en/Detail/Index?id=438984277084451053&appLang=en&os=Win32_64
Try to uninstall this one first.
Filip
Viveka_CD
Hi @Anonymous
The most common cause is a version mismatch between the Modelo Revit plug-in and the Revit version you are using.
As the first step, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Secondly, if this occurs only on one machine, then I suggest that you find another machine that has this plugin that does not get the error message when opening Revit and copy the config.ini from the C:\Users\user name folder\AppData\Roaming\Autodesk\Modelo\RevitPlugin and copy it to your machine.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Thank you.
ecjoseantonio
estou com um problema ao iniciar o Vray o revit trava. não abre o Vray
@Viveka_CDwrote:
Hi @Anonymous
