05:10 AM
- Mute
- Permalink
- Report
Good afternoon all,
I have a custom window (attached) where when the cut plane and top level is set below the window still shows some elements of the window.
There shouldn't be anything visible. I've purge all the other window elements out that worked correctly.
I believe everything is set 'only show when instance is cut' however this seems to make no difference.
Any suggestions?
Thanks in advance,
K
