Why won't "attach top/base" attach both side sides of gable roof?
svalen
svalen
This happens just about every time I try to "attach top/base"
Why does this happen and how can I get rid of this other side of the wall?
Split the wall in half, Attach each side, and then use Join Geometry to hide the edge between the Walls.
constantin.stroescu
  • Try to slightly move up your roof and the problem will be solved. Or create a wall on 2 levels, so to avoid the triangle profile.
  • another way is to use Edit Profile for the wall and while in Edit Profile , lock the upper lines to Roof Bottom
Constantin Stroescu
