Why will section cuts not display in certain plans?
svalen
svalen
I have adjusted the "display coarser" settings
I have checked the crop area and made sure it is big enough
I have checked that the category is not turned off.
I have adjusted for discipline
What could possibly be the reason my section cuts don't show on some plans?
Phase? View filter? Hide at scale smaller than...?
RDAOU
@svalen
You can also check the crop region of the section. If the crop region/extents of the section does not intersect with the view range of the level in question, it will not show on that level.
  • Either select the section in the plan it shows in and uncheck crop view
  • Or In an elevation stretch the extents of the crop region to cut the levels below/above as necessary
