Why the plant not show in the schedule?
I am try to create a planting schedule. I placed three type of plant and there are only two type of plants show in the schedule. I discovered that the plant cannot show in the schedule is not in the same group of properties as the other plant. (When I was placing the plant it was in the same group of properties with other plants but after placed the plant it is in another properties.) I guess it is the reason why it cannot show in the planting schedule? How can I make the plant show in the schedule? Thank You.
Only two type of plant showing in scheduleOnly two type of plant showing in scheduleWhen placing the plant, it is in the same group of properties with other plantingsWhen placing the plant, it is in the same group of properties with other plantingsAfter placed the plant in another group of propertiesAfter placed the plant in another group of properties
Add a family field and you might see it.  Your schedule is showing type comments and common name - that plant may not have those fields filled in.
The plant have those family field, but the schedule is not showing this plant. And the parameter is created as shared parameter.
the plant have those family field.JPGThe parameter is created as shared parameter.JPG
Did you place it in a different Phase of Construction than you're Scheduling?
I use another plant family and the new one works, thank you.
Seriously?  That doesn't explain why the first one wasn't reporting though.  Have you watered it lately? Maybe it's dead.
That is a Site family, not a Planting family.  That is why.
