Why is Revit slightly changing edited profile lines of walls meeting sloped roofs?
Anonymous238
Anonymous238
To make the walls join correctly in the first image below I have to edit the profile lines of the wall instead of attaching it to the roof above. When I do this Revit then randomly skews the lines like you see in the second image below. Why?
kbevingtonN6US5
Try attaching the top of the wall to the roof elements. Modify walls -> Attach Top/Base and select the roof. You can do this twice, once for each portion of roof. This also allows the wall top to adjust automatically if the roof height/slope change.
mari.shimode
Hi @Anonymous238, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
