Im using R2017, but i can save my file and the file browser (folder, drive) doesnt load/work
i need to use the "escape" key to back the proyect and try again but without succesfull
Solved by dgorsman. Go to Solution.
Is this a workshared file?
Have you been able to save at all - to any location?
its not a workshared file.
I cant save any file like project, template, or family, only i can export to autocad
Can you do a SaveAs?
I can not save as
Apparently the file browser is loading (but I can not see it) and the menu and revit' ribbons are turned off instead.
This is sounding like a classic "dialog box off screen" problem. Usual solution is this:
Give the process a try with your browser window, or another open application first so you know what to expect.
The file browser has was in the auxiliar display, because we have set the second display as primary and now we are working with just one, when i connect another monitor and change the primary display the file browser was there,
Now we'll be more carefull when if we change the primary display
thanks so much!
Regards
