Why cant I 'Save' a Central File?
jnoordzij
jnoordzij
I have enabled worksharing and then saved as a Central File. After that I've done some workset management inside the central file, and now I want to hit 'Save'. But 'Save' is greyed out.  I can only select 'Save As'.
Why is this ????
Do I need to 'Save as' and then 'Save as Central File' over and over again ???
zemeraloni
Hi @jnoordzij
You can't save because it is a central file. press the sync icon (see attached) to save your model.
