Why can't EQ be written?
4 REPLIES 4
jdhF2S5U
333 Views, 4 Replies
jdhF2S5U
I want to mark EQ on the drawing. Can you tell me why not?
I clicked on the curtain wall line.
4 REPLIES 4
ralphdenhaan
in reply to: jdhF2S5U
ralphdenhaan
Can you be more clear about what you want to achieve?
Do you want another text instead of EQ? maybe a printscreen of endgoal?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
syman2000
syman2000
I assume when you click on the EQ symbol, the start and end dimension will state EQ while the middle portion will not.
I only notice this issue exist if your curtainwall is set to fix number, fix distance, max and min distance. Only way to get the equal to work is to make sure your curtainwall is set to none. Then move around the curtainwall grid
Then press EQ and you should get your symbol
handjonathan
handjonathan
Hi @jdhF2S5U
Thanks a lot for posting your question to the forums!   Has the solution suggested by @syman2000 helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Hi @jdhF2S5U
Jonathan Hand
Because the the border dimensions are not 1,090 mm.  You can edit the curtain wall type and uncheck this box then you can have EQ for the entire string.  But keep in mind the border curtain panels will not be the same size as the interior ones.
