Why can' I change the name of a schedule while a view template is applied to it?
cjpmurray
Message 1 of 11
cjpmurray
I have created a view template to schedule each of the partitions in the project. However, I have noticed that if I want to change the name of the schedule (as shown below) I have to take off the template in order to change the name.
I have more or less than 20 schedules for my partitions, and I'm wondering why this isn't similar to a instance parameter or something like that. Because everytime I adjust the name and take off the template I end up having to move all columns that I have moved to fit on the sheet. It has become very annoying having to do this every time I have to make a name adjustment.
Please if anyone knows any workarounds or if I am missing something i am open to listening.
Replies (10)
Message 2 of 11
I can change the View Name without turning off the View Template.
Message 3 of 11
cjpmurray
I can change the view name too but that's not what i'm asking. It's the header in the schedule as shown here.
Message 4 of 11
Not following you. That header is the View Name.  What am I missing?
Message 5 of 11
Edit the Template and clear the Formatting box then you can re-title as you want.
Message 6 of 11
cjpmurray
The view name does not change the header. It only changes what you see on the Project Browser in Schedules. See image.
Message 7 of 11
cjpmurray
Yeah I guess that works, but would like it where I wouldn't have to mess with the template like that. Im just going to have to re align all my schedules then. I hope that no one wants to change the font or text, because that would be a real pain having to do that manually for all the schedules.
Message 8 of 11
After rename you can recheck the formatting box and the column widths any other formatting will be back to match the template.
Message 9 of 11
So, you do NOT want the Header Title to match the View Name and name in the Project Browser?
Message 10 of 11
cjpmurray
Yes, the header has more information that i don't need on the Project Browser
Message 11 of 11
cjpmurray
I don't have column widths applied because it varies every wall partition, and have to manually change the widths to keep it all info on one line. I think i'll try turning off the formatting and if becomes an issue then i'll just go back to what i have been doing. Just wish the header was something you could edit without having to turn off and turn on something
