Why aren't previous threads not bumping to top of "All"?
Anonymous238
Anonymous238
The forum has been redesigned and when I add posts to older threads, the thread is not showing up under "All" tab in the forum. Curious if this thread will appear in it as well.
RSomppi
It seems to be working on this end.
Anonymous238
Should probably provide evidence - here is a thread I bumped and its not showing up - be aware that I did just duplicate this thread with the same title and this one obviously has different responses: https://forums.autodesk.com/t5/revit-architecture-forum/default-double-hung-double-window-into-tripl...
RSomppi
I don't see why I should provide evidence of it working but, while trying to do so, I discovered that that thread seems to be behaving differently than other threads.
Anonymous238
Lol I meant I* should probably provide evidence not you
CGBenner
@Anonymous238 @RSomppi
The differences you are seeing are likely because of the test being run right now on a proposed redesign of the forums.  You are welcome to offer your feedback HERE.  Thank you!
Chris Benner
RSomppi
I'm pretty sure it's not by design if threads are acting differently. In this example the thread the OP is referring to does not move to the top of the list when I respond but other threads do. I don't use the term loosely but it sounds like a bug.
