I can't generate the PDF in Revit 2025/Não consigo gerar o PDF no Revit 2025
2 ANTWORTEN 2
Nachricht 1 von 3
gipiragis
128 Aufrufe, 2 Antworten
I finished a project in Revit 2025 and I can't generate the PDF because the program crashes. It has required an absurd amount of memory and then crashes. I tested on more than one computer, with greater capacity, but the problem persisted. I need help to download the project because it took hours of production. I believe it is a problem with the program, perhaps because it is a newer version. Can anyone help me, please?
Finalizei um projeto no Revit 2025 e não consigo gerar o PDF porque o programa trava. Tem exigido uma quantidade absurda de memória e depois trava. Fiz o teste em mais de um computador, com maior capacidade, mas o problema persistiu. Preciso de ajuda para conseguir baixar o projeto porque foram horas de produção. Acredito que seja um problema no programa, talvez por ser uma versão mais nova. Alguém consegue me ajudar, por favor?
Tags (1)
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: gipiragis
Please review this Knowledgebase Article
Crash on Print to PDF or launching Print Preview in Revit 2025
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
handjonathan
als Antwort auf: jay_colcombe
Hi @gipiragis
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
