Why are my storefronts not showing in elevation?
gmasis6WD44
Message 1 of 8
gmasis6WD44
Any idea why these store front curtain walls are not cutting thru the wall? As you can see, in plan, I can see the store front (s7) but in elevation, the wall seems hidden behind the wall and this seems to be the case for all the windows above that are a part of that wall. They should look like the windows on the left indicated by arrows in elevations. I've made sure the properties and conditions are the same.
Replies (7)
Message 2 of 8
GustavoUbriaco
Hi
Does the type properties of the curtain wall have the embed option checked?
Gustavo Ubriaco Contreras
Message 3 of 8
gmasis6WD44
Yes embedded in properties. Coworkers couldnt figure it out either so may be some sort of anomaly.
Message 4 of 8
GustavoUbriaco
How about the phase created of the elements?
Message 5 of 8
gmasis6WD44
Same phase as the other storefronts. I've tried deleting, copying, pasting. I am trying to avoid having to draw a profile line around it to avoid any issues later on.
I fixed the windows above by restoring all elements on that wall but can't do the same for the ground for some reason.
Message 6 of 8
Check phasing.
Message 7 of 8
syman2000
Is there any design option for the particular curtainwall?
Message 8 of 8
GustavoUbriaco
Let's try to cut geometry in the modify ribbon, maybe they were uncuted or disjoined during a movement
