Why are my curtain walls showing up like this?
Message 1 of 17
I'm designing a skyscraper for my architecture studio class, and on some floors, my curtain walls show up like this (see picture). On some floors, they are just fine like they should be. Please help!curtain wall.JPG
Replies (16)
Message 2 of 17
Is the Curtain Wall Mullions Category turned off in the View?
Message 3 of 17
I checked my visibility settings, and everything seems to be checked! I also checked the hidden layers and nothing is hidden.
Message 4 of 17
post the file
Message 5 of 17
cbcarch
Does the curtainwall span from Ground Level to the Roof? Or do you have separate CWs that span from floor to floor?
If you have a single CW, then a visibility setting in certain views is likely the problem.
If you have many CWs, then it could be a Type that you used did not have a mullion type specified, or something else wrong with it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 6 of 17
Lower or raise your View Range Cut Plane a tad.
Message 7 of 17
martijn_pater
@cbcarch wrote:
...or something else wrong with it.
That one solved it j/k^^. Do the mullions show in a 3d view on this level?
Message 8 of 17
My money is on View Cut Plane cutting through the Mullions in the Plan View.
Message 9 of 17
Heres my file. If you could change it and tell me whats wrong it'd be very helpful!
Message 10 of 17
which floors do you have the issue?
Message 11 of 17
At least 23 and 27. Not sure if theres others yet.
Message 12 of 17
Edit your View Range and change the Cut Plane height. Works like a charm.
Message 13 of 17
To what? I've never been in this part of Revit
Message 14 of 17
couple of inches works for me.
Message 15 of 17
Adjust your cut plane a bit so that it doesn't cut right at the horizontal mullion.
Message 16 of 17
Thank you guys so much!
Message 17 of 17
I think you ought to buy a celebratory round of Solution Credits for us all.
Bottoms up!
