Which function has the parameter "Class" in a Material? and how does it differentiate itself from a Material Category?
aksel_alvarez
aksel_alvarez
Hey folks! I'm working in a Material Library for a project and want to use the opportunity to create a Library that helps us to automate and improve our LCA-calculations as well our Arch-Viz work.
As you can see in the picture below I'm a bit intrigued by two aspects of the organization: Material Class and Material Category.
I made a quick search for some info about those parameters and the knowledge database seems to don't have any information regarding them. This article https://cutt.ly/WQzGPfX just have an overview of the parameters but doesn't go deep into the question, a deeper insight on materials is available in this article https://cutt.ly/ZQzHnRI but as usual, the focus is on the appearance of the materials.
I'm guessing that the Class parameter is there as a means to allow the work via API with materials (you can check it in the API docs site here https://cutt.ly/gQzHFoi) and the "Category" is just a way to organize a Material Library that doesn't have an impact into the Model's data structure.
What I can't understand is why these classes are predefined as they are in list #2 and which effect does have that a specific material is classified in one or another class.
I'm guessing it right? Are there some examples of best practices that I can check to orient myself? Does somebody possess the knowledge about what these parameters are and why they are organized the way they are? (see list marked with #2 in the image)
Thanks in advance for your help!
Use for Filtering:
