Which element would suit best as a decorative, non-strucural "support"?
dariawerynska
dariawerynska
Hi fellows!
I have modelled an auditorium and I wonder if it's possible and purposeful to include some more decorative elements in Revit or you would advise to model it in some other 3D software.
Below I attach my idea for the auditorium. I want to model these green lines as wooden panels. Recently I modelled fancy stairs using a command "roof by extrusion" and now I'm wonder if there is some other smart way to model the idea from the drawing.
What to you think?
Yes you can use Revit tool to create those: architectural columns, non structural beams, etc...
aRcHiTeCt.JM
... hi @dariawerynska
.... you can create anything you want
.... take a look at these frames and elements (attached .rvt)
... you can model entire families in any material
.... if you need help just ask me... I love to do that
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
I would build them in the model just as you want them built in the field, and  I would use loadable components, just as @ToanDN suggested.
