Where is the toposurface button?
husman1
husman1
Im new to revit and im following a tutotial on youtube it uses toposurface and they dont have the toposolid button.
I need to use the toposurface but cant seem to find it and when i use toposolid i cant edit elevation like the youtube video.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Where is the toposurface  button in my messing and site tab?v]
mhiserZFHXS
Toposurfaces were replaced with toposolids in 2024. You either need to use an older version of Revit or work with the toposolids.
husman1
how do i change elevation with it
mhiserZFHXS
What do you mean? Like raise and lower the entire thing? Or add points to add contours?
handjonathan
Hi @husman1
Thanks a lot for posting your question to the forums!   If you could give some more information on changing the elevation as @mhiserZFHXS has indicated that would be great. This information will allow the community to help.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
GHASEM_ARIYANI
https://www.youtube.com/watch?v=6xDROANKaHo
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
