A book I am reading says to click the Edit Crop button from the contextual panel on the ribbon.
I cannot find this. Can anyone tell me where it is?
Thank you for your help.
If you're talking about the crop box around a view when in a sheet (which is what it looks like), you should be able to just select the outer edge and drag it to size!
Viewport --> extents --> crop view --> size crop
Click the viewport, scroll down to the extents section of the panel. Check the "Crop View" box, then up on the ribbon the modify panel will pop up with a Size Crop button.
Scroll down in your properties window and under Extents make sure Crop View and Crop Region Visible is checked. Then select the crop region, the tools in the panel will appear.
I am not sure you you are looking for the View command you don't need that and you don't need to be on the view tab of the menu bar... All I was trying to say was that you were on the wrong tab
All you need to do is the following (previously described above) ...
Hey @Anonymous
Did you manage to get this to work?
Hey all, I had the same problem and found a solution for the edit crop button. Make sure your Scope box is set to NONE !!
