- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm wondering whether people use Revit detail views, Revit drafting views, or AutoCAD to detail. The biggest bonus to Revit is that it updates things automatically but it such a poor understanding of the things it's showing that it often just becomes a hassle. For example, floors not only are essentially just consistent extrusions of the same section but they also put their hatches over top of structural members which leads to a mess only really fixable by pasting a detail item of the beam over the beam that already exists. It looks bad enough in a section but in a detail it's simply worthless.
Here's an example of the floor issue. If you show the real floor it's just a mess. I had to make a detail item with a mask where the steel plate turns upward. The panels that actually fit between the beams also don't show up properly. Also bear with me, some of my rage is because I'm coming into the project after someone with incredibly limited experience has done the work up until now.
I saw one person on a different website off-handedly saying that they draw over the model in a detail view and then turn it off so only their detail lines remain. Is that a common way to be able to go in and just snap detail items and lines to relocated/changed elements? It seems that would be fastest, but it feels wrong and clunky for something like this.
Insight would be greatly appreciated.
Peter
