- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I currently have both Revit 2022 and 2023 installed. I cannot for the life of me find the default UniformatClassifications.txt file. New projects based on the Imperial-Architectural template indicate the file should be at C:\ProgramData\Autodesk\RVT 2023\Templates\English-Imperial\UniformatClassifications.txt but there is no such file, and the Assembly Code Settings dialog shows a yellow warning triangle at the File Location field.
Where do I find this file? Is my Revit install somehow incomplete?
