Where can we find such Annotation?
4 REPLIES 4
pearlofsadness
1019 Views, 4 Replies
Hi, I would like to create this specific type of FFL (Finished Floor Level) Annotation, Drop Annotation (D symbol), Width Annotation symbols (W)... But I am not able to find it. Anyone knows where can we access it? I am assuming it to be fully editable so I can change the Symbols like FFL, D, W etc including the Numeric Digits (I am assuming it does not adjust the height itself like the Original Spot Elevation).
4 REPLIES 4
hmunsell
in reply to: pearlofsadness
You could use the Spot Elevation for that and change the Prefix as needed for FFL, W, D. Your issue will be the symbol your using (the box around the text). I'm not sure off the top of my head of any other Annotation types that will show an Elevation.
Howard Munsell
pearlofsadness
in reply to: hmunsell
 This is good enough already! Since I can easily use the Existing Spot Elevation for both Drop and FFL, may I know how did u modify the family to have it show Width too?
hmunsell
Width...? I may have misunderstood your prefixes :-). I thought the "W" was for "Window" elevation and "D" was for "Door" elevation. it looked like you were taking elevations at openings as well as general floor level.
if you want a tag the Width of a opening, I would modify the Window or Door tag and tag the specific element with the appropriate tag.
use the Prefix option in the Label to automatically place the W Prefix for you.
Howard Munsell
pearlofsadness
Exactly what I needed. Thank u 🙂
