For some reason I can't find a way to get the existing and demo walls to show a line where they touch. The endcap is missing. See the attached PNG file for a better understanding.
Thanks for the help
Thanks for the help
Solved by rosskirby. Go to Solution.
Select the wall to be demolished, right-click on the grip at the end of the wall, and select "Disallow join".
Is there a way to do that globally? I have a ton of walls that need that done to.
I'm afraid not. The automatic behavior for walls is to join.
