When Revit puts the door, the gap does not open
7 REPLIES 7
Message 1 of 8
turhanabdulkadir
416 Views, 7 Replies
When I add the door in revit 20 or 10 door drawings, the door comes but the gap does not appear. Everything is in place in 3D
7 REPLIES 7
Message 2 of 8
Lower the View Range Cut Plane so that it intersects with Door.
Message 3 of 8
As @barthbradley states this would typically due to the Cut Plane in that View.
You can check this in the Properties Palette > View Range > Edit
In this example this is a Standard OOTD View with a Cut Plane Offset
This example is where it is placed above the Door
Jay Colcombe
Autodesk Certified Instructor
Message 4 of 8
Hi @turhanabdulkadir
Thanks a lot for posting your question to the forums!   Has the solutions suggested by @barthbradley @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 5 of 8
You might also be seeing the Door that way because you are view in the "wrong" View.  Maybe you're in a Ceiling Plan View - not Plan View.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
Message 6 of 8
Thank you very much for your interest, but I have looked at each floor level unfortunately I am on the correct floor plan.
Moreover, I am not the only one with this problem. We are also looking for a form with similar problems
Message 7 of 8
Message 8 of 8
It was solved from the view range. You guys are great. Thank you very much.
