When I Orbit Model Changes Colour ( Simplifies)
Revit 2017 query.
When I am in a 3D view and I hold shift and mouse wheel and move my mouse to orbit my model, the colour of the model becomes simplified - such that the edges disappear.
Is there a way of not making the edges disappear and maintaining the graphic detail level while in orbit motion?
I am sure there was a setting in previous versions where I could turn this off but I cannot find it now.
B
ennujozlagam
@Anonymous hello, you can try untick use hardware acceleration and or set your graphic display options to realistic and see if this helps. thanks
Turning off Hardware acceleration made no difference.
Turning on realistic does give the results I seek however the redraw process is very slow due to Revit having to redraw the model at a Realistic Graphic Level.
I seem to remember though in previous versions, what I am looking for could also be done in Shaded mode.
loboarch
Could be the "Allow Navigation During Redraw" setting. Try setting this the other way than it is now and see if it changes what you are seeing.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-3E3BAFAA-9C6E-44A4-A6BA-D5B56B845F0E
Jeff Hanson
Principal Content Experience Designer
Revit Help |
No, that doesn't work either.
