When I hover over the rooms, they don't get selected
Message 1 of 11
Hello All,
I stumbled upon another problem which I don't know how to resolve. Usually when I hover over the rooms in RCP, the rooms get selected. I want to drag the floor down from the section view so that it can be aligned with the floor to do the lighting calculation. But for this instance, I am not able to do it. Any thoughts will be highly appreciated.
Kind Regards,
Prattusha.
Replies (10)
Message 2 of 11
is the category turned on in the view?
Message 3 of 11
By category, do you mean the space in the VG tab?? yes that is turned ON.
Message 4 of 11
Space? I thought you said Rooms.
Message 5 of 11
Oh dear...yeah..I meant rooms..yes..I have that..but then If I go the section view, I can't select the  room boundary.
Message 6 of 11
check your limit offset
Message 7 of 11
I can't even select the room !!!! 😞
Message 8 of 11
no, go to plan view, select it there, and  then check to see if what its upper limit is set at.
Message 9 of 11
I just checked, and there is no RCP for the particular floor.!!! Ohh dear!!!
Message 10 of 11
How is it possible!! I have a ceiling plan but then I don't have RCP when I go to the View tab!!!
Message 11 of 11
amorap
Hi from Spain.
Select the room and verify in which level is placed.
Unless you have done any change, the bottom of the room should be placed in that level.
With the room selected verify the offset values in properties palette.
Also, you can set de height value in a level in order to perform the area and volume calculations. Select the level in a section view and set the proper value in the properties palette.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
