Revit 2017 Shortcut is missing
I have a student version of Revit 2017 which I did uninstall, deleted all the pertinent files from various folders, cleaned up the registry entries as well ( using the instructions from: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2016/...) and temporarily disabled the Windows 10 Defender. Ran the install by clicking on  "Autodesk_Revit_2017_English_Win_64bit_dlm_001_002.sfx.exe" (I had downoaded the ..._002_002.sfx.exe as well). I clicked the Finish button after the compleion of the installation. But, I could not find the Revit's shortcut icon to run the Revit! Searched for Revit.exe, but, could not find it! Checked the Control panel (Uninstall or Change a program)  and there was no "Autodesk Revit 2017". I have all the other parts required to run the Revit such as material library, content libraries, MEP Imperial Content v2.0 and etc. I hope the picture is legible. Any help or suggestion will be appreciated.
ennujozlagam
@Anonymous hello, based on your screenshot i dont see any Revit program install? you can check it HERE on how to install. you can download the software thru Autodesk Virtual agent. switch off all your anti virus program. hope it helps. thanks
Mark.Lancaster
@ennujozlagam
Are you replying to someone?  Smiley Very Happy
Not sure what happened but your reply is all by itself.. Smiley Wink
Mark Lancaster
I had to uninstall the Revit 2017 (using the Autodesk's Uninstall Tool) and reinstall it. It works fine now. Thanks all.
ennujozlagam
@Mark.Lancaster hello, what do you mean? i'm replying to @Anonymous. have you read my posted suggestion. thanksSmiley SurprisedSmiley WinkSmiley Tongue
Mark.Lancaster
@ennujozlagam
Your reply came in as a new I&L posting by itself..  It looks like the moderator combined them with the actual one...  Smiley Wink
Mark Lancaster
