This is standard scheduling formatting!
You need to sort by a Field as it is reporting multiple values and hence reads varies!
You could do it by date or number and hide this field if necessary.
This will need to be done in the sheet family if the Revision schedule is embedded in there.
This solved it. Thank you!
