Whats the best render software?
heitz15
Message 1 of 9
heitz15
Hi guys,
Im new to Revit, im more used to use SketchUp + Vray. Ive heard the Vray doesnt support Revit yet, so i would like to know whats the best softaware for Revit. Im using the 2016 version of Revit now.
Thank you guys already
Replies (8)
Message 2 of 9
DarrenP
Revit has rendering built into it have you played with that yet?
DarrenP
Message 3 of 9
heitz15
No,
Actually didnt get there yet, mate. Would you say that this Revit render is as good as the top render softares? (Vray, Lumion3D, etc)
Message 4 of 9
Darin.Green
Vray is by far better than the Revit renderer. If you already know vray, I can pretty much guarantee you will NOT like the Revit rendering capabilities. Another way you can render your Revit models is to use 3DS MAX Mental Ray...
If this information was helpful, please consider using the Accept Solution
Message 5 of 9
dgorsman
Close to it, at least.  The big benefit with in-program rendering is no translations/exports/etc. needed, nor are there tons of obscure settings that mean little to a designer.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 6 of 9
Correction, VRAY does support Revit. It is only very recent and is currently in beta.
https://www.vray.com/vray-for-revit/
https://www.youtube.com/watch?v=_tvLY7ffBHo
So far the testing I have done is positive. There are obviously things that need to be addressed, but it shouldn't be far away.
In the meantime, if that doesn't satisfy you, then yes, best method we currently use is export for 3Ds Max rendering.
Message 7 of 9
heitz15
Good to know man. Good to know.
But, woud you say that VRay is actually the best render software for revit? (Are you familiar with the others? MentalRay, Lumion3D, etc)
Message 8 of 9
Darin.Green
The best rendering software for Revit currently is 3DS MAX (Mental Ray). Although, vray is in beta stages, it's still not supported yet. <-- Hopefully it will soon! 🙂
Message 9 of 9
As far as I have seen & based on the comments of the Vis guy next to me, 3Ds Max with VRAY.
However, recently I have heard quite a bit of talk about maxwell render and Enscape. I will make clear though, I have no experience with them. Perhaps those who have can compare and make comment?
http://www.maxwellrender.com/index.php/products/maxwell-render-suite/plugins/
http://www.enscape3d.com/
Lots of options!
