- Mute
- Permalink
- Report
I'm customizing a floor plan Visibility/Graphics setup, and as I'm going I'm making my walls have dashed cut lines. As I go I'm noticing all the walls' edges are comprised of two lines. This wasn't visible until I changed the walls' edges from solid to dashed lines. Does anyone know what the second line is? Obviously one of them, I'm guessing the thicker line (I haven't modified the line weights for walls), is the edge of the wall. But what is the other one? None of the subcategories under walls (Common Edges, Hidden Lines, Cornices and Trim) toggle the visibility of this thinner line, so they evidently are not connected to this line. This is also evident because the thin line's pattern stays the same as the thick line's pattern (if I change Walls to Dash Dot, both the thin and thick lines take on this pattern).
Any ideas? It would be nice to be able to modify this thin line for different View Templates.
