If there is a best setting, why would they provide you with all those variables!! they would just give you the ONE and only BEST setting!!! or like the top 10 settings for you to pick from.
Rendering is a Graphic Art...the term BEST in such case does not exist because of the settings you use, the verdict on the outcome/result is matter of taste!
Stipulate the Quality Setting option on the Rendering dialog.
To generate a preview image, render it as quickly as feasible. High-quality soft shadows and replications are rendered. This option works well in settings with simple lightings, such as interiors and exteriors.
And for more information, you should go for the Revit Architecture Course.
