What are these points in the screen?
Hello. I’ve been experimenting with Revit and learning a few things.
What are these points in the screen? When I grab something in the project those are always showing.
I thought was a DWG but there are none attached to the project.
aRcHiTeCt.JM
… hi @Anonymous
… looks like
… those points are from a structural floor
… unchecked the section box
… you will be able to modify the floor
... and see the entire floor with those dots in that view
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Those look like Analytical elements - turn them off in your VG.
Took me a couple of minutes to discover that it is a floor in a group and it is pinned. Now finally I can see that.
What are Analytical elements ? What for ?
They are used for analysis, such as structural analysis (look at the categories). You probably don't need them on.
