What Are the Default Settings in Revit for the Compound Ceiling?
2 ANTWORTEN 2
Nachricht 1 von 3
KGARRETT5
215 Aufrufe, 2 Antworten
I accidently overwrited the default settings, and just want a simple answer for this one so I can change it back!
Under Structure what is the Metal Stud Layer thickness and finish thickness?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: KGARRETT5
It really doesn't matter, you should use what fits your design.  But I would say the default compound ceiling type is 4" steel studs and 1/2" gwb if imperial.
Nachricht 3 von 3
Get it back?  The defaults that are in the RTE?  You could open a New Project using the RTE and then use Transfer Project Standards.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-C...
