What Are the Default Settings in Revit for the Compound Ceiling?
KGARRETT5
KGARRETT5
I accidently overwrited the default settings, and just want a simple answer for this one so I can change it back!
Under Structure what is the Metal Stud Layer thickness and finish thickness?
It really doesn't matter, you should use what fits your design.  But I would say the default compound ceiling type is 4" steel studs and 1/2" gwb if imperial.
Get it back?  The defaults that are in the RTE?  You could open a New Project using the RTE and then use Transfer Project Standards.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-C...
