Weird roof joining issue
simsekmelih2
Message 1 of 16
simsekmelih2
Hello, I hope you're all having a fantastic day! I do not know how to explain my issue besides screenshots, so here they are
Basically, I want to get rid of that weird extension to the other side of the roof. I tried using vertical opening to clear out that area, but it did not work. Any suggestion is appreciated, thanks a lot!
Replies (15)
Message 2 of 16
Post your RVT file and I'll show you.
Message 3 of 16
Make the main roof as 2 pieces and join the dormer roof to one.
Message 4 of 16
simsekmelih2
Thanks a lot, worked very well! I also want to remove the red part, is there a smarter/easier way to do it without changing the footprint of the roof?
Message 5 of 16
There's more than one way to skin a cat.
Screenshot shows two differently pitched roofs - having  different plate heights (Offset for Roof Base) - intersecting. Revit is smart enough to do this as a mono roof.
Message 6 of 16
What red part?  Can you share a pic?
Message 7 of 16
simsekmelih2
Ups, the image was not uploaded, sorry!
This area:Capture.PNG
Message 8 of 16
simsekmelih2
Revit is surely smart enough, but I am not sure if I am 🙂 Thanks a lot, I will give it a go
Message 9 of 16
Roof by Extrusion for that part.
Message 10 of 16
Like this?  If so, it is easier to model it as one roof as @barthbradley said.  See attached 2022 file.
Message 11 of 16
simsekmelih2
I am a bit confused now though, I am trying to remove/delete that part of the roof, not trying to add new part
Message 12 of 16
simsekmelih2
Exactly, can you also share the blueprint, I couldn't recreate the same...
edit: Just saw your attachment, checking it
Message 13 of 16
Then don't do roof by extrusion.   See my first Screenshot. That's all you need; right?
Message 14 of 16
simsekmelih2
Thanks a lot for your time and help, but why do I have it this shape? Is it because my roofs are not perpendicular to each other? Because I am literally adjusting blueprints in the Revit file attached aboveCapture.PNGFxfG8TZRK9.png
edit: meh, I increased offset from roof base and it's fixed. Thank you so much for your patience! 🙂
Message 15 of 16
You can orient the roof however you want.
Message 16 of 16
simsekmelih2
Thanks a lot for your time and patience with me ^^
