Weird Geometry in one View
andrewsmith20
andrewsmith20
I had this geometry show up in my South Elevation, deleted the elevation made a new one, nothing. Does not show up anywhere else. Any thoughts on what's causing it and why I can't find the source elsewhere?
L.Maas
Might be a graphics glitch. Sometimes the graphics card gets data that it does not know what to do with and then you can get weird artifacts. It might be something in one of the elements (or an interaction between elements) that has something that causes these artifacts.
Try the following (on a backup/copy of the project):
-Start removing elements from your model and see if issue dissapears.
-When you know which element it is, try to modify/rebuild/replace it and see if that solves the issue.
-If it is a graphics glitch updating (graphics card drivers, OS, Revit) also might help.
-Test it on another computer and see if same issue present
Louis
Please mention Revit version, especially when uploading Revit files.
andrewsmith20
Mine happened to be two floors colliding making the weird geometry. Deleted them and replaced them, all good now. Thank you
