Weight Calculation in Revit Schedule
niteshpanchal
niteshpanchal
I am adding Sheathing Board to my structural project and the client need to know the number of the board with their weight in KG. Can anyone helps me how I can calculate weight in Revit? I have attached some technical properties of the board from the client and Revit family for the same.
Thank You!
denis_borodin
Hi, add a new property (Nominal density) to your rfa, then use calculated formula in schedule to multiply density, height, length and thickness. You will get the weight
Denis Borodin, BIM Manager. LinkedIn
niteshpanchal
Hi Denis,
Thank You! for quick solution.
