Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Weekly New Knowledge Articles by Support team | Mar 20 - 24th, 2023
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
25-Mar-23
Connections get created on opposite column side in Revit when import SMLX file from Advance Steel
Connections imported on opposite side in Revit from Advance Steel
Yes
25-Mar-23
Elevations and sections with irregular crop regions are incorrectly mirrored after using the Mirror Project tool in Revit
Some elevation and section crop regions are mirrored incorrectly after mirroring project in Revit
No
24-Mar-23
Users reported that it is not possible to set the Heat Transfer Coefficient value to the required one in Revit
Cannot set the Heat Transfer Coefficient value to the required value in Revit
Yes
24-Mar-23
Users reported that custom roof parameters not exported to IFC from Revit
Custom roof parameters not exported to IFC from Revit
Yes
24-Mar-23
Users reported that pipes from linked IFC model are located far outside from model in Revit
Pipes from linked IFC model far outside from model in Revit
Yes
24-Mar-23
When powering electrical devices in Revit, the Space Name and Number are not automatically added into the Load Name of the created circuit.
Space information not associated with Load Name automatically in Revit
Yes
24-Mar-23
Render in Cloud button is missing in Revit LT
No
23-Mar-23
Dynamo starts very slow in a non-internet environment for Revit 2023
Yes
23-Mar-23
Is it possible to convert a Revit Family file (RFA) to a STereoLithography (STL) file?
How to convert a Revit Family file (RFA) to a STereoLithography (STL) file?
No
22-Mar-23
How to optimize the positioning of elements through Dynamo in Revit?
No
22-Mar-23
Revit closes unexpectedly when working with MEP models.
No
21-Mar-23
How to control the visibility of nested point cloud files in linked cloud models in Revit?
No
21-Mar-23
When importing in Revit a SMLX file exported from Advance Steel model, most elements are missing. Only some grids are visible
Missing most elements when importing SMLX file in Revit
No
21-Mar-23
Users reported that nothing is displayed after IFC import in Revit
Nothing is displayed importing IFC in Revit
Yes
21-Mar-23
When opening a model in Revit, the process hangs at loading linked Structural models and never completes.
Revit hangs during the opening process when loading a Structural model and never completes
No
21-Mar-23
When the size of the pipeline changes from larger to smaller, gaps are created between the fittings and the pipes.
When the size of the pipeline changes from larger to smaller, gaps are created between the fittings ...
Yes
20-Mar-23
Users reported that opening IFC file exported from Archicad-26 is not possible in Revit.
"Cannot open filename.ifc" when importing IFC from Archicad-26 in Revit.
Yes
20-Mar-23
Revit creates an additionally center line between connector in a duct fitting multi port family.
An extra center line is automatically created that extends beyond the family instance in Revit
Yes
20-Mar-23
Users reported that user defined property set related to IfcProject properties is missing in exported IFC from Revit
Missing property set related to IfcProject properties in exported IFC from Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
