Message 1 of 19
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys, is there any way to create this type of wall in Revit? The wavy layers are a must. Thanks!
Not with a System Family...ie: not with a basic wall no you cannot.
Now it behaves like a wall more or less
I am not very familiar with nesting the family, can you elaborate? or place the file here so I take a look?
Watch the attached GIF...Nesting means when you stat an In-Place Component in the Model, Instead of creating forms, Click in the component button on the ribbon and place an instance of the family ...as simple as that
Alright, thanks a lot, will try soon!
A bluff...That would cut the layers and not generate multiple wavy ones...how would that look in plan views with 2 or 3 layers in the core as per OP ... odd no?
I need the wavy layers, not just wavy insulation, it would have no purpose, the wavy layers will reinforce the wall. This is for 3D concrete printing.
Another alternative ...you can create an array of model line curves in a line based family.
You need to export the Lines to .STEP no? so you do not really need the Geometry of the infill layers between the outer and inner skins. Your model would then consist of:
Yes, that's correct, but the project still needs to be done in Revit, for visualization. Currently we working on a plug in to generate a centerline for the concrete layers, as the only possible way from Revit to create centerlines, is with the analytical model, but it's a no go for me. But thanks a lot for the info. I appreciate it.
You would still be modeling it in Revit...it is just for the export purposes you would use the model lines
You model a custom profile using the Profile-Reveal.rft (family template).... model the profile offset behind the reference plane in the right hand zone annotated WALL >> Load into project and assign to a reveal type >> when you place it, it will cut behind the wall face at a depth = to how much offset you gave the profile
upload the generic model to see what/how you modeled and if it is feasible to make it parametric or if there are alternatives to get you to what you to the desired results
Here it is, again, I am very grateful for your help!
You have used an extrusion of a profile consisting of spline ... while spline are easily parameterized in massing and adaptive family environment, it is not doable in the basic loadable families.
What you could do is, instead of modeling the voids straight in that generic family, use nested families using the face based template...
This is a bit far beyond my knowledge, can you share an example? it's easier for me to get that way. Thank you!
