Want to explode Cad 3d model with layers in revit
cavitnation
cavitnation
Hi
i Want to explode Cad 3d model with layers in revit.
when i do that i am getting some errors.
Import contained some 3D data or points which can't be exploded.
Any solution to this ?
RobDraw
You'll need to examine the DWG to determine the cause. Revit doesn't like a lot of things that can be in DWGs. They often need to be dummied down in order to be usable when exploding.
Rob
You cannot exploded 3d cad import in Revit. Create parts from it and override parts geometry and material if needed.
